ORIGINAL: 924nutter
ORIGINAL: SteveSJS
Could be wrong , but believe the oval type back box is for the exhaust system associated with the 2.7l 924S.
Don't think it will fit the earlier type of system, but then willing to be proved wrong if you have suitable cutting / welding gear!
S
If you look down the "spout" of the 2.5 litre box you will be staring into blackness but do the same to the 2.0 litre oval tailpipe and you will see baffles, as they are of different internal construction.
If you look closely at the oval tail pipe silencer of the 924 you may see the large weld close to the box underneath, where the oval trim is attached to the silencer; I believe that an oval trim was avialable for the round pipe. I don't have PET on this pc. let me check the part numbers and I will post. I suspect that, inline with Porsche's continuous improvement poilcy the oval pipe will fit but you will most likely have to buy the front silencer as well, as I believe that the round pipe is a one peice up to the downpipe flange, whereas the oval pipe terminated so that either a catalytic converter could be fitted for the US or a second box for ROW.
