Exhaust Pre Silencer rusted to H/Exchanger
- Thread starter 993 C4
Dr D
I had some issues replacing my heat exchangers - but no real drama as the garage dealt with it. good luck
When the nut comes off and drops on the ground don't be tempted to pick it up. For a few minutes at least.
Or take it to a specialist and they will use heat. But they may/should warn you that 100% success is not a certainty and broken studs/bolts can still happen. They will thank you profusely if you just bring the car to them for removing rusted exhaust fasteners and you then take the car back to do the rest of the work.
