Exhaust Recommendation - 981 Manual Boxster GTS ?
drhildr
Have the dreaded stuck valve on PSE - might just replace with an aftermarket option - any thoughts on a reasonably priced system that links to PSE actuation?
You haven’t indicated your car’s series - 986, 987, 981, 718 - but there are lots of options out there for a range of prices. I’m not sure that you’ll find a system that links directly to your PSE actuation - most probably will use a separate fob actuation - and it’s likely that they’re going to be louder [and maybe boomy?] than the current system.
For starters, have a look at offerings from Topgear, although systems are available from other suppliers such as Milltek, Remus, etc.
Jeff
Have you tried the penetrating oil and molegrips approach to the valves. They can often be freed up by soaking with oil and leaving for 24 hours, then applying gentle pressure.
