exhaust tips
cobalt911
Hi there,
I am making a grand assumption that Porsche OE exhaust tips (big chrome) will fit a C4S or is there a different fitting out of the silencers??
Anyone fitted turbo tips to their 's'?
Cheers,
Mark
Hi, I think the whole subject of exhaust tips for 993's is pretty complicated [:(] As I understand it, there are different tips for narrow bodied vs wide bodied, then different tips within the various ranges - small bore, wide bore, Motorsound etc.... plus various aftermarket options to add to the mix Sure someone will be along with the "One True Way" in a while [;)] Pete
Hi Mark, I have some experience of this as my local Porsche Centre supplied me with the wrong "Sports Tails Pipe" (This is the name used in the original Tequipment brochure for the 993, big oval pipes). There are different sports tail pipes for standard body and wide body cars and different again for the Turbo. The standard body pipes are straight through, i.e. the inlet and outlet pipes are in line. The S and 4S inlet and outlet pipes are offset. The pipes for the standard body are interchangeable between left and right, the wide bodies are not. Part numbers as follows :- Carrera and Carrera 4: 000 044 200 01 Carrera S and Carrera 4S, left: 993 111 981 02 Carrera S and Carrera 4S, right: 993 111 982 02 Turbo, left: 993 111 981 01 Turbo, right: 993 111 982 01 They look great but are bloody expensive. As you can see I am really busy on a Monday morning. Aren't recessions great !! Cheers, Mark Thompson
