Here is the tale of the exhaust. I phoned 3 exhaust shops for a price to do the work for me, two of which wouldn’t take it on as they weren’t supplying the exhaust. The third one said they would do it but they needed to take a look at it first. The reason for this was that in their words ‘ it’s a 2 hour job and if the nuts are corroded it could take longer and the price would go up’. They quoted £98 for 2 hours work. I thought this could turn out to be double the quoted price so decided to do it myself. I decided to tackle the infamous nuts on the exhaust flange next to the primary cats only to find that I couldn’t get a spanner to fit, 10mm was too big and 9mm to small. These nuts are supposed to take a 13mm spanner I believe. They had literally shrunk in size due to corrosion. To remove these nuts I had to resort to using a dremel to split the nuts. Anyway to keep a long story short I have completed the install today. I took it for a run and these are my findings: Upon start up I was over the moon, the difference is night and day and I was 110% pleased. When driving with the window down in a built up area the sound bouncing back off the walls was awesome. The bad part is that despite what people say, there is a lot of booming between 2000 and 3000 rpm, not just a bit like people claim. I took it on a duel carriageway and driving at 70mph was quite acceptable, no different to the stock system. I didn’t notice any increase in power to be honest although one would think the deletion of the secondary cats must give rise to some increase. So to sum up, the jury is still out because I have only took it for a short run. I will let you know my thoughts in a week’s time.
