My rear exhaust box is rattling on my S2 and it appear whilst it looks perfectly good on the outside the baffles on the inside have come loose. It looks like i need a new rear box. The dansk seems to be the best option? Is it worth removing the cat whilst I'm at it and fitting a decat pipe or is this just not noticeable for the money?
Exhaust
- Thread starter moosec
ChasR
Dansk seem to be of a variable quality for now it seems. The older units seem to last years whereas the newer units can last months. In your shoes I would be tempted to buy the new old stock exhaust on eBay (as pricey as it is) or get a custom back box made up via an exhaust specialist.
The exhaust on my 2.7 is different from my S2, the manifold/ exhaust joints have the bolt holes as a mirror image of each other - much to my annoyance!
Ex Skyline
Contact JMG for a full Fabspeed set up mate, including 3" Turbo elbow [8D]!!
The bits that are different on mine are the 2 x 3 bolt joints at the bottom of the 2 x 2 into 1 manifolds, the vertical section near the steering shaft, after that I cant be sure as the 2.7 has a custom one from there back. I like the sounds from the custom setup, so took both systems off, to swap it on to the S2 and it wouldn't fit! Gaskets are the same just mirror imaged. So I just have the custom rear, it has slightly larger tailpipe and no little box in front of the axle.
