exhausts
- Thread starter Guest
Why do you want to replace? Rusty, more performance, better sound?
There is plenty of experience on this board but we need a little guidance before we can say anything sensible.
HTH
Richard
This is an equal length, no crossover system, meant to give about 10/15 bhp more on forced induction. Single outlet, 3". Looks almost standard, apart from 2 flanges hanging down slightly.
Sounds better (I have the least noisy version, with a slight boom at 1,700 revs), and drives better (the supercharger revs easier), but no back to back tests.
The Hayward & Scott systems would mean replacing your perfectly serviceable HEs. It is a 3 into 1 header type system that uses a 2in 1/2out rear muffler - like the pre 74 cars - so its quite different from what you currently have. Gains in torque and peak horsepower are often claimed for this type of system but to really exploit them you need some clever chip remapping. 15hp is about the most you should expect - perhaps less. Last time I looked H&S were £1600+. You can do the same kind of thing with SSI HEs and a 2in 2out muffler of your choice for less £££ than H&S, say £800 plus muffler, depending on where you buy.
You have the cheap (but perfectly acceptable) option outlined above. The mild steel parts in std configuration are fine and should last 5+ years.
If you want to spend more you can get stainless components. The crossover pipe and premuffler get a lot of road crud stuck to them so stainless may be a smart bet. The choice of rear muffler is up to you: single or dual outlet? quiet or noisy? big tailpipe or std size? Budget on £200ish for mild steel and £350+ for stainless sports. Be aware that 2out mufflers require cutting the rhs rear valence and that 2 out sport mufflers may have insufficient back pressure to make full midrange torque.
Off the top of my head, online vendors may include Essential Styling, Design 911, Type 911, Berlyn Services, but there are more.
Hope that helps.
RB
ClubSport 911
http://www.triadwestperformance.com/images/CRANEY_TXT.htm
IMHO, unless the engine is re-mapped between changing the exhaust system, then frankly, all you are proving is just which system works best with any one ignition / injection timing etc.
The only (sure fire) way to conduct A:B:C etc... modifications is either to normalise or optimse. Normalising is a monster job. Optimising is easier.
Unless they modified the system to get the maximum out of the exhaust then the results may be less meaningful than otherwise.
Steve
This is only a replacement so you wont get any gain in performance and it sounds like original one ( which sounds sweet anyway!)
ORIGINAL: bones
If you decide on a two in two out system what you need is one of these
and read this too
Don't expect spectacular bhp gains from exhaust mods on a 3.2.
Do they have a UK distributor and UK costings? Looks like a nice lightweight exhaust, hopefully without resonance due to its crossover design. Just looking at it, it is hard to believe it isn't a little restrictive - two right angle bends - but the dyno results (if accurate) tell a different story. Should also be good for midrange torque with the crossover design.
While we are on the topic of exhausts, I wonder if anyone can volunteer the price of a pair of SSIs sourced from a UK distributor. Who is the cheapest? Any thoughts?
RB
bones
Triad don't hava a UK dist' , they are fairly loud but make a glorious 70's rally Porsche type sound and make the horsepower others claim. I doubt the improvement will be quite so substantial on a 3.2.
Keep an eye on E-bay there is a firm in Birmingham who sell new bits cross over, pre-silencer and rear box all in stainless. I bought a cross over pipe from them and it looks good. Got a stainless pre silencer from Specialist cars of Malton including gaskets for £138 including P&P delivered next day. Fitted it with all new stainless bolts what a difference. Baz
