My 1990 c4 has started to produce blue-ish smoke from the exhaust at idle and under acceleration. From the smell of it it almost certainly oil that is being burned somewhere along the line. With the engine compartment open there is also a haze of blue smoke that drifts into the engine compartment from the vicinity of the exhaust secondary silencer area (i.e. drivers side of the engine compartment).
I cannot see any oil dripping onto the exhaust and the smoke stops when the engine is stopped (bummer).
The car has done 102,500 miles with full history but has not had any sort of engine rebuild (yet!)
There is no noticable fall off in performance or untoward noises.
The distributor belt appears to be intact.
I'm guessing that I'm looking at an engine rebuild (top or whatever) but I thought I would just ask to see if it could be anything less wallet damaging. I'm moving house in the next few months and so it would be good to know what I need to budget for.
So to recap the symptoms:
Blue smoke at idle when the engine is at running temperature.
A puff of smoke when the throttle is depressed that clears after 20 seconds (hot or cold) but returns at idle or if the throttle is lifted and then redepressed.
The exhaust fumes smell like burning oil.
The car doesn't appear to be using excessive amounts of oil. About 500mls in 3000 miles or so. However I have only noticed the smoke in the last 50 miles.
The oil level on the dipstick is between max and minimum.
There is no drop in performance.
There are no horrible noises from the engine (yet).
There are no warning lights illuminated on the dash.
My car has the M150 option and so has no Lambda sensor.
My wallet is now very scared [
