Love my Boxster, but it is an S&M relationship: Sadly almost every time my Boxster has been in for warranty work it has had to go back for redoing, or remedial work:
1) Drivers door window limit switch replaced, followed by:
leaking drivers door - wet along bottom, carpeted edge, so
a) replace the door seal on drivers side and passenger side (got me!)
b) in to replace membrane in drivers door - replaced passenger side instead
c) in to replace drivers door membrane, done but trim not fixed properly
d) in to fit trim correctly,
and last week
e) in to replace drivers window limit switch again (1 year after orginal was replaced), and, joy of joys, no leak.
2) "noisy" front nearside wheel bearing detected at service, replaced under warranty, followed by:
a) in to refit disc shield which was loose and hitting the disc.
3) Various dash rattles, followed by
a) tighten dash, and we found another and sorted that
b) in to sort rattle that was found and sorted
c) in to tighten dash to sort the rattle that was sorted and a new rattle now on drivers side.
So currently only two dash rattles remain!
4) In to sort knocking at rear (I believed the rear LH strut had failed), followed by
a) Can't hear anything Sir,
b) Ah yes we can, trailing arms replaced (actually never got 100m away afterwards just turned straight around, pulled out a technician and there that noise, "... that'll be the rear LH strut Sir." Hmmm, that's what I said...)
c) Failed rear LH strut replaced.
Problems all solved now since the warranty has expired, and since it is a company car... until I buy it off the lease!
How much of a premium on the price of each car does this inefficiency cost I wonder?
