Those of you considering the extended warranty should bear the following in mind.....
2 months into my first extended warranty period and I get an airbag warning light on the car. "Thank God that I finally decided on the extended warranty" thinks I, and got the car booked in. I've just had a phone call from the stealer to say that I must underwrite 1.5 hours worth of labour (£175 !!!) before they will complete the diagnosis (i.e. just to find the fault - not to actually fix it). I challenged this and was told that if the fault turned out to be a component then all would be covered by the warranty - no charge, but if the fault was with the wiring this wasn't covered and not only would I have to pay the £175, but also the additional cost to fix the issue as well [
Unfortunately I don't have the warranty booklet to hand and so I cannot check the detail, but the above story should be considered by all - it seems that the warranty and the "peace of mind" it buys might not be as much as we'd been led to believe.
