External side window trim
- Thread starter Guest
Steve Humphreys
Steve
Fred Hindle
You may have to do this every two years (I do on my 964).
Cheers,
Fred
Fred Hindle
If you are using an aerosol to spray the area then approx 12" should be adequate.
Work using a sheet on newspaper (double thickness, use the fold that is already there). A tip here is to place the sheet of newpaper (already folded) on the rear screen. Place your masking tape so that it is 50% on the paper and 50% on the glass, press the tape down onto the paper firmly, lift the paper and tape up and then place in position for masking. Before using tape and paper mask the area off just using masking tape, then when you are happy with that masking then apply tape with paper attached, sticking it to the tape and don't forget to stick the other end of the paper against the car to avoid it falling over your fresh paint etc.
Sorry if I haven't explained this very well, it is easier to do than to explain. Need any other info email me off forum.
Cheers,
