Failed MOT on 996TT with modified Exhaust !
jonluik
Hi Guys
Just tried to put my 996TT through its first MOT and it failed !
1. Exhaust Emissions. The CO is 0.61% Vol but needs to be less than 0.30%.
The Exhaust is not a standard one, its was installed by PSI motorsport. Any suggestions ?
2.The car is a left hand drive and failed on the fact that the rear fog lamp is incorrectly mounted to the left side (should be rightside) Any suggestions ?
Many thanks.
I would guess that it has sports cats.
I assume that since it was sold for road use, these ought to meet the requirements.
Additionally the emmissions are also affected by the lambda probes that come before and after the cats.
I guess it would be worth checking these to make sure they are in good condition and still connected.
I don't think there is going to be some easy way to halve the CO, like using a different petrol brand.
You could try asking PSI?
I thought the light clusters were symmetrical to make production easier/cheaper.
If the wiring is present, then I would guess it could be a simple as just taking the bulb out of one side and putting it inthe other.
If the wiring is not present, then it will be a little more involved to reroute it across to the other cluster.
Try finding an MOT station with a tester who can be a little flexible in attitude. That guy/gal sounds like a Natzi.
Jon,
mine is LHD, it had it's first MOT a couple of months back and no mention made of the fog light. MoT was carried out by an OPC.
Problem Solved !
I took it back to where I bought it from and they managed to pass it by making the exhaust very hot.
They also rewired one of the reverse lights to make it a fog light.
Job Done.
Hmmmm interesting as I thought there were two foglights at the rear?(one either side) and would'nt the reversing lamp be a clear lens?
Only 1 foglight is wired. Bulbs are usually present in both though!
The usual thing is people wanting both working, a wire across from the "working" one is the easy way to achieve this.
