GOOFY
Hi
My Boxster 2.5 24k , failed MOT today due to high (co?) emissions. The tester with some experience of Boxsters stated it could be 3 things:
1. Lambda failure - said he could get these for £80
2. "U" clamp from catalyst to exhaust leaking .
3. Catalyst failure - he had just changed a set on a Boxster (which he duly showed me!)
In trying to work out the best course of action I assumed the following:
1. if the lambda had failed would this not show up as a (engine) warning light ? And should I get diagnosis from OPC to confirm ?
2. The "U" clamps were indeed leaking as these were removed and re-installed after some heavy chisseling which have put them out of shape. Secondly the exhaust fitted is one of those similar to the PSE , with the bypass pipes around the silencer. Can this really affect the emmission readout ? I have also fitted an induction kit and foam air filter and have always experienced a mild flat spot in mid range before 4000 rom. Is this connected as well ?
3. Any way of knowing for sure if it is the catalyst ?
Any advice would be most welcome - as I have 10 days to figure this out !![8|]
