Fan Ballast Resistor
toals
I need to replace a ballast resistor on the driver side cooling fan. I have located the resistor which is tucked up just in front of the wing liner and held in place by two clips. Problem is I can't see where the cable connects to the loom. Is it reachable without removing the wing liner/ FPU ? Any advice would be most welcome.
Seamus
I replaced both of mine not too long ago. The workshop manual tells you to cut the wires and splice the joints, which is by far the easiest way to do it. If you want to use the new plugs supplied with the resistor you have to take quite a lot of bits off to reach the fans where the plugs are located. I cut the cables and soldered them together, and used heat shrink tubing to seal the joints. HTH.
Edit: instructions added.
