Fan Belt problem
- Thread starter Guest
check to see if you have a "C" spanner in your toolkit. It fits round the top pulley, allowing you to hold it steady, while you take the nut off the centre of the pulley.
Once the nut is removed, you'll find that the front section of the pulley slips off the shaft, along with some spacers. Note the order in which the spacers were fitted. The spacers are put either side of the front of the pulley and adjusts the tightness of the fanbelt. The more spacers on the inside of the pulley, the slacker the belt and vice-versa.
I found that when I put the new belt on and used the same spacer positions, it was just the right amount of play in the belt. It may have been luck, as both the belts were the same length when new. Its not a law, just might save you messing about with trying different spacers and having to remove and tighten the nut up each time.
The belt should flex about 5mm at the midpoint. Check it after running the engine at 1500rpm for a few minutes. Remember to stop the engine first though [
The nut should be tightened to 40Nm (30 ft-lb) [
HTH
Malcolm
