JamesBall
After even "spirited" drives, the cooling fan doesn't continue to run after I have turned the ignition off. If I turn the ignition back on, the fan kicks in and belts out warm air, but stops again when the ignition is turned off.
Assuming that this is not correct (!) can anyone advise me a possible cause? I am guessing a temperature sensor somewhere but then if that had failed, why would the fan start when the ignition is back on?
