Fan problems!
williams
My cooling fan seems to be permanently on. This means the battery dies when the car is parked unless I remove the fuse.
Would this be down to a faulty switch somewhere or a relay and if so, is it gonna be expensive?
Paul
Radiator switches make a habit of dying in this way - not expensive new as I recall.
Regards,
tref.
Thermo switch is £8 and the relay is about £30. Could be either - unplug the thermo switch and if the fan continues to run you have a duff relay. If they stop then the thermo switch is at fault.
