Super_Marv
Hi Peter,
I remember a while back you said that you had to replace your ABS Pump, because the windscreen washer reservoir leaked onto it.
Can you remember if it triggered the ABS light on your dash?
I've had my specialist look at the ABS on my 968 while it was in for its service - he wasn't able to put it in to the place where he normally gets the ABS tested, as they were too busy, but he tried new speed sensors, relays and and a new control unit and the ABS still isn't working. The light isn't coming on, though if he removes one of the relays or cables it is (so the light does work)
The only thing which he hasn't replaced is the pump...as he didn't have a spare and new ones are about a grand! We both suspect it's the pump (even though it does whirr up when driving off and when the ABS is needed)
If your pump was seized and the ABS light was not coming on, then it may point at it being the pump with my car. Though the windscreen washer reservoir hasn't been leaking...
Cheers,
Marv
Cheers,
Marv
