robsangster
Ok Have just finished a fairly major project - namely an engine replacement on an S2 - changing all the usual bits inbetween.
Overall it has gone very smoothly indeed and she is running superbly, which given that almost everything has been apart, we're quite surprised by!
However she currently has a high idle. Cold around 1600rpm dropping to 1300 once warm. No fluctuations, hesitation etc etc. On the road she performs faultlessly making me think its nothing too major (fingers crossed)
Haven't had a chance to start going through the list of check points - this weekend sees that - but thought I might throw it open to suggestions.
Obviously air leaks, TPS and the like will be first ports of call, But my first question is this, namely because the vacuum lines had already been disconnected and im not sure on the correct routing.
The PET shows a Y piece coming from the Pressure Regulator (rear of fuel rail nearest to firewall) - clarks just shows a bend - both versions lead to the manifold Y (as does the line from the damper)
Can anyone tell me what theirs does? A simple bend connector from the regulator - or a Y and if its a Y - where does the third section lead to - if anywhere?
I current have this
Line from Damper and Regulator joining at a 'Y' at the intake manifold.
I also have a line from the vacuum valve to the Throttle body.
Point to note this doesn't go via a thermo valve like the coupe Page 84-86 of PET - Thats it
The other vacuum line dealing with heater valve is all hooked up correctly and working fine - so we have no confusion there!
Sorry if this has come up before - I couldnt find anything and unless Im missing a trick - the PET and Clark show slightly differing situations.
Its a 1990 Cabriolet by the way
Any help with the Vacuum lines question - or thoughts on general high idle greatly appreciated - prior to our weekend check list!
Regards all
I current have this
Regards all
