MikeH
While I've got no complaints about the performance of my 911, more mundane cars are definitely a lot quicker than they used to be. I'm starting to think it might need an engine rebuild in the next couple of years (after 30 years on the original lump, it probably wouldn't hurt) and maybe I should squeeze some more power out of it while I'm in there...
I'm not about to rush into this, so I thought I'd start this off as a chatty thread, and see where it goes....
It's a 3.0 Carrera (I think it's basically the same as an early SC apart from cam timing), so I'd be very interested to hear others' experiences... it strikes me that there's potential for more power, largely due to the very low compression ratio, and I notice that Newman Cams list a set of cams which might help, for fairly sensible money.
I'm also involved in messing with KJet VWs, which benefit from tweaking the Warm Up / Fuel Pressure regulator to increase the fuelling a bit. Worth about 10 bhp on a standard Golf Mk2 1.8 16v
I see the obvious pitfalls as
1. The ability of KJet to release any much more power from the engine, and the possible 'metering flap flutter' problems associated with Kjet and hairy cams. Although some Ferraris run KJet I think, so maybe the power output isn't an absolute constraint?
2. Keeping the mixture rich enough, and the engine cool enough to avoid pinking at higher compression (richer mixture, bigger injectors, extra oil coolers?).
So what's been done? What information resources are out there to help? Are there 'standard' components to swap over, which can help to release more power - e.g. higher compression pistons?
The only constraint I'd place on this is I want to stay at 3 litres, rather than going for bigger barrels and pistons...
