Faulty brake pad wear indicator.
I know it's faulty because I've just had new disks and pads all round. The little rascal comes on after about ten minutes driving.
Where is it located on the caliper and is it easy to fiddle with? I really cant spend any more money at a garage this month.
If you look through the wheel at your brake calliper you will see a piece of red wire going from one pad to the other. That is part of the wear indicator. Have a look on p-car.com under the section on changing brake pads for some pictures and a better description.
pp
