My car is just back from having a new water pump and turbo heat shields fitted. When out last night, I thought the left hand main beam was a bit low. Checked the headlight level adjustment by turning the light switch on and then turning the ignition on and the left hand one is not moving. The connections to the front and rear level sensor appear fine. There are no faults logged on PIWIS. Am I looking at a new drive motor for the headlight level adjustment?
Faulty Litronic Headlight Level Adjustment
- Thread starter minny
You should be able to check the motor in Drive Links in the HBA module on PIWIS. If one isn't moving up and down as you activate it, I would check the connector on the headlamp tray first, before splashing out on a new motor.
Yes, that's the one. I had one go on my Turbo. They are about £100 though []
