Ive got a problem on my oil pressure gauge, when I turn the ignition lights on the needle shoots straight to the top past 5 till it hits the max pin and stays there, even when I start the engine it dosent move,when I turn the engine off it goes back down again after a couple of seconds. I dont beleive theres anything wrong with the engine as it was rebuilt about 6k ago and runs fine,so its either the gauge or the switch,could anyone please tell me how if possible I can check the gauge or the pressure switch to see which is at fault and also where the pressure switch is located on the engine please.
