EddySpaghetti
Hi All,
I'm on the verge of buying a car, just trying to decide between two that I have been to see and have a few questions:
Is it an issue to fit S2 D90's to a Turbo SE? - looks like there is 13mm offset difference at the front end only (I guess because SE has the largest Brake Calipers??) - The arches are rolled on this car so it would be less likely than most to foul, but are there handling / wear issues to be considered?
Second queston is about an S2 I have looked at. The sunroof was slightly damaged around its edges. Bloke selling it said it was made of fibreglass. I never knew they were - is that correct from factory, or is a replacement? If it needs repairing, is the fibreglass more/less difficult than metal to work with?
Again on the S2, behind the belly pan there is a metal 'bottom of something' that has ribs/ridges on its lower surface. If there is oil there what are the potential leaks? - Steering felt a little heavy so could it be steering fluid and would a loss of fluid make the steering heavy? Belly Pan itself was dry at front half of it.
Lastly, if the driveshafts have some slop, is that an indication of gear box issues or just worn CV's? - car has highish mileage and more slop than others I have looked at with 50k less...
Thoughts on the above very welcome! - I found out a week ago that I'm unlikely to get made redundant (has been hanging over for last 2-3 months) so can finally get on with buying a new car.
I sold my old pride and joy just before the bad news came out and resorted to buying a £400 runaround to keep me going, but I need a proper car again soooooon.
Cheers,
Eddy
Cheers,
Eddy
