Figure this one out!!
rcsalmons
Can anyone help me out?
The car - a 944 Turbo S 1988 with Tial 38mm, 3 bar FPR, MBC, chipset.
So I took the car to Chris on his Dyno, it produced 294Hp @ 17psi boost. Fuel curve looked OK.
He also highlighted the car was running v.rich at idle and part throttle approx 10:1 AFR.
Changing the ecu took the AFR upto 14.5:1 and all OK at part throttle. However I have now lost a lot of performance, the boost labours in and I would guess power is down to 200 ish hp.
I tried a different make of chipset still the same.
Then swopped AFM, KLR and DME with known good units - thanks Paul. Still the same!
Reverted back to original ecu and the car pulls like a train again - AFR problem still there.
I am now going through all the DME/KLR wiring but if anyone has any ideas please let me know I am at a total loss.
Have checked all temp sensors, tps, DME relay.
Rich
