finally taken the plunge
- Thread starter Diesel130
ORIGINAL: Diesel130
Yes - its taken a while - still seems a big step to make :-O
It will be worth it when you get behind the wheel.
denisoreilly
Diesel130
Spent around 2.5 hours looking over the car, armed with my notes from discusssions on here and my Peter Morgan 'ultimate buyers guide'. Even phoned up Porscheworx who serviced the car last summer for advice - very helpful chap there (Mario I think he said) his name was), who ran through what had been done and seemed to know something of the history of the car.
Am pinning my hopes to the fact that its only 46,000 miles and had a good service history. Its had new brake discs, brake fluid changes and all regular services and has a tracker fitted. Didn't see any receipts for more major work - I would have preferred if it had had a new engine, gearbox and clutch last month (!), but couldn't see any signs of oil leaks underneath, not any signs of accident damage. The clutch pedal felt smoother and lighter than the last one I tried and it didn't make a horrendous rattle on start up that I've heard on others before.
The only negatives are that the front tyre treads are getting a bit low (they've worn slightly more on the inside than the outside, but I understand that is normal with the 996's camber angle) and that it has 17", rather than 18" alloys. But I guess an upgrade to 18" would not cost the earth if I decide to go down that route in the future. Peter Morgan's book says the 17" are more compliant, so maybe that's not a bad thing for our broken roads around Suffolk. The other thing I noticed is the tick over seems a little low (only just over 600rpm) - is that normal ? - there was a bit of vibration noticeable in the cabin at tick over. Anyway, I'll have Colcherster OPC take a look at that in particular. Otherwise, it drove very nicely.
ORIGINAL: Diesel130
Tickover should be 680 rpm.
Wheels i would not worry about to much had 17" on my C4 and when i needed new tyres bought some Turbo 18" wheels with new tyres cost the same as 4 new tyres and these wheels look so much better, and i think the ride is better too.
Will be intrested to see pics, hope all goes well with the inspection.
Phil
Diesel130
yes ... months !ORIGINAL: philippe
Sounds like you have done your homework.
where did you get those from ?ORIGINAL: philippe
Do you normally notice a significant vibration in the cabin at tick over ?ORIGINAL: Richard Hamilton
Vibration not a massive ammount but you can see the passanger seet move a bit, if the idle is not set 100% this may cause it, ask them when you have the check done.
I hope all goes well let us see pics when you have done the deal.
Phil
Has the car had the big 48k service done or is the previous owner selling up just before?
My tickover is at 750 (with no vibrations), and was 800 before I fitted a sports exhaust.
The idle speed is not adjustable at all (not even with a PST2). It is programmed into the DME, and the only way to change it would be by reprogramming.
Diesel130
ORIGINAL: Rodney Naghar
It had an OPC '48,000', / major service in 2004. An OPC 60,000 minor service in 2005 and an independent major service, new brake discs and a few other bits last summer. So should be due for a minor service next year, if I understood the service schedule correctly.
Good news...sounds like you've done your homework....should end up with a great car....fingers crossed for u, you'll love every minute of it!
DME Set point for tickover of engines with Motronic 5.2.2 (non eGas cars) was 680 rpm (engine hot). When version 7.2 was introduced, the idle was raised to 700 rpm. 750-800 is slightly high.
Good info Rich....another word with the OPC me thinks
Diesel130
ORIGINAL: philippe
... hope all goes well with the inspection.
Phil
Booked in for 9am Wednesday
Diesel130
ORIGINAL: philippe
Sounds like you have done your homework. When you have the inspection i would try and be there while it is done the opc you use should let you go over the car while it is being inspected, as you seam to now know a bit about these cars you can ask questions.
Phil
Great news - it passed ! Only two (small) issues; lower of 2 tone horn not working and cigarette lighter not working. Tyres are low tread depth at the front, but I knew about that. Engineer complimented it on its smoothness and taughtness.
So, just need to sort out payment/collection details and await its new MOT - hopefully picking up at end of next week !
