Uberdave 191
I had all sorts of bother with this last year. Does anybody have a solution to my problem? On the rear parcel shelf there are only 2 mounting points for the Bracket. Obviously, (or to my mind) there should be 4 to enable 2 sets of harnesses to be fitted. There are 2 further screw points on the shelf, but my man at Tech 9 says these are not for use.....and are too small to screw a suitable bracket into? My concern is that being a lard arse one mounting point locating both attachments would not be sufficient to retain me in a crash. My man at Demon tweeks advises the singular bracket should not be relied on. Car has a factory fit Matter cage and doesn't have the crossbar which most people can rely on.
Cheers.
Uberdave.
Cheers.
Uberdave.
