I've finally got a gearbox for my s2 and i'm fitting it tommorow, i had a look underneath today and it all looks straight forward except for the selector shaft, will the box wiggle off the shaft before it hits the spare wheel well or does it get more complicated than that? is there anything else to look out for? any advice much apreciated. cheers, Rich.
Fitting a gearbox
- Thread starter quickrich
barrysmith
if you have a ramp,, use a gearbox stand, on lowering the GB you can then simply disconnect the linkage.
Erm ... it's more complex than that. And a pig of a job. It's about 60% of the clutch change procedure ...
From memory:
From memory:
- Driveshafts off
- Remove selector rod from gearbox (small rubber gaiter needs pulling back, then there is a bolt to be removed)
- Gearshift gaiters (inside car) off - remove gearknob and work from there
- Remove gearlever (circlip gets the selector rod off, then 10mm or possibly 13mm bolt at the bottom and it will be free)
- Pull selector rod ALL THE WAY FORWARDS from within the car. It will move about 12 or 14 inches, and you will skin your hands doing so, but it needs to come as far forward as possible
- Find access panel on the side of the gearbox bellhousing - approx 4 inch trapezoidal rubber cover on the side of the bellhousing, and pull it out
- Undo two pinch bolts on the sleeve inside the access panel (very tight) and slide sleeve back onto gearbox
- Support gearbox, remove two support bolts from the top of it, lower and remove
