Fitting an S2 engine into an 84' 8v 944
- Thread starter Guest
Peter Empson
You are right about needing the loom and ECU. You'll also need an S2 exhaust and throttle cable (plus bell housing and clutch which should come with the engine hopefully). I would strongly recommend going for an S2 gearbox too, it's something of a weak point on the Lux so having to deal with a lot more power can't be good for it. The original torque tube (and even radiator) should be fine however.
In hindsight the easiest way to do it would probably be to buy an accident damaged S2, you really need the other car there to do the swap easily. This was one of the biggest issues on my car, it caused Dave at JZ major headaches sorting out all the plumbing (electrical and otherwise) and we ended up needing more parts off the donor car than we ever thought about despite research and planning.
The airbox was a bit of a pain, on the S2 it obviously lives under the badge panel but its too large to go under the one on the Lux, the solution is to use a cone filter but there isn't any real air flow under there (there's ducting on the S2's bumper for this) so I ended up fitting a 924 Turbo badge panel which solves the problem nicely. However I fear your panel may be welded in, I seem to remember that was the case on earlier cars?
It goes without saying you will also need wider tyres, better brakes and suspension.
I hope all this hasn't put you off, its not a completely straight forward swap and does involve a lot of labour but it can be made to work very well.
Best regards,
Peter.
