Fitting Electric Seats
- Thread starter Guest
The fuse box is divided into 3 parts, and these fuses (25A) are 1/2, starting from the cockpit end.
Bit technical, maybe, but the book is a bit confusing, picture wise, and the car is in the garage (and I'm too lazy to look ?)
steh
john is right, the power is direct frrom the fuse box and is wired befor the fuse as the seat has all the ness relays and things in them. reason is that if you were in an accident the seats could be opparated without the key being on. this i read from an old 911 and porsche world help page.
steve
The power cable will probably be already fitted through the bulkhead (standard wiring looms), the cable from fuse 2 is marked 'red/red tape' - it is also connected to the A/C.
Anyway, worth finding it, as you know it will have all the power you need, and will work correctly.
