bennyboy
I think this has been discussed before, but I would like some detail or other ideas if possible. I'll be using a 4-pt harness, so the two shoulder straps can go to the cage and the outer lap belt to the lower seat belt mount. The inner lap belt is my issue. I have just recieved some harness eye bolts and mounting plates from DT, which a Peter and Fen advised me to weld to the transmission tunnel. However, there is not much thread in the plate, so unless I drill a hole for the eye bolt to pass through, it wont be holding onto much. So, has anybody ever drilled into the tunnel? Is there much clearance to the torque tube? Or is there a more simple solution? Thanks, guys.
