Fitting OE Non-Airbag Steering Wheel
- Thread starter roygarth
That appears to be the wheel fitted to non airbag 993 RS.
I have it in mine, very comfortable with good location at the ten to two position.
Any reason not to???
Well, since you asked.... I considered, but never fitted this wheel on my previous airbag equipped RS, on the basis that if I removed the airbag, what if I ever needed it...they are apparently very good in an accident?
I have this wheel on the CS, which is caged (not that safe on the road), but also has 6 point harness,,,you tend not to move very far!
If the CS came with airbags, I would not remove them...each to their own [
You will only find out it's true value if it is ever used. Sitting on the shelf in the garage and it is totally useless.
I would assume the first indication of airbag problems would be the airbag warning light flashing on the dash display, these things obviously have a shelf life, but I am not aware of any bulletins from Porsche insisting they are changed after a certain number of years.
On the basis that some manufacturers are keen to replace cambelts on a strict schedule, if they could justify more £$€ from the public on replacement airbags for their own safety, I am sure they would.
Anyway Piers, enough of this gloom,,,that RS wheel, really does feel good to use! [
Scenario,
1,,,,accident........no air bag fitted = zero benefit.
2,,, old dated airbag fitted,,,,,somewhere between 0-100% chance it goes off and provides a benefit.
The point being the probability of there some benefit above zero, by having an airbag in place is likely.
lets not dwell on this too much, empirical evidence does show the benefits of airbags in an accident. Can we dispute that?
If we were that concerned, we wouldn't even get in an old Porsche and go near a track, we would all be driving around in 5* Ncap padded cell Suv's [
carrerasport
C
