edh
I'm looking for the best options for this - finding good locations for the senders isn't easy
There's also the question of where to measure oil temps - do you want the temp of the oil that's about to lubricate the bearings, or the temp at it's hottest? (or both?)
Think Auto suggested using a sandwich plate with 2 machined adapters for their mechanical senders (or for someone else's electrical senders). This would sit under the oil filter & measure the oil post oil cooler. The plate is around £40. Will take 1/2 BSP or 5/8 UNF senders (that's the next problem! - finding compatible senders)
Then there's the challenge of finding gauges closest to stock - I reckon the siemens vdo vision ones are pretty close.
http://www.merlinmotorsport.co.uk/INSTRUMENTS-VDO-Cockpit-Vision-Gauges/c1_2_3/index.html
- or the Smiths Eclipe range - they can supply 5/8 UNF senders. I might be able to use their senders with VDO gauges.
http://www.caigauge.com/International_Instruments.htm
The Think Auto (Mocal) gauges are close, but have white needles. They do a combined pressure / temp gauge which saves space.
http://www.merlinmotorsport.co.uk/INSTRUMENTS-MOCAL/c1_358/index.html
It's mechanical though - routing 2 oil lines looks a bit awkward. I've routed the boost hose through the grommet that the main loom from the DME/KLR passes through. I can get 2 more wires down there pretty easily.
I'm going to mount them under the radio - the dials should help illuminate the rocker switches as well...[]
