Fitting rear seats belts
Billygoat
[FONT=arial"]I have a 1986 944 Turbo without rear seat belts. I have purchased a set of rear lap belts from a 944 breaker. The donor car was a similar age and I have been advised that they will fit my car.
Can anyone give any advise as to whether these lap belts are easy to fit?
Thanks.
JB
[FONT=verdana,geneva"]
It's an easy enough job, can be a bit fiddly getting the bolts started in the threaded inserts in the body shell, but all up an easy job.
You can also buy 3-point belts that will fit - there's a mounting point on the pillar
Are you sure there's a high mounting point on an '86 car? You might be right, but I think that came in in the '87 or '88 year.[FONT=verdana,geneva"]
not totally - there was one on my '86 924S though - but I know assumptions can be dangerous ;)
Cars without seat belts donot have the bracket fitted to the rear bulkhead, which provides the upper fixing for inertia reel belts, certainly Jon's 85/86 car doesn't. But its not a big job to remove from a salavge cars, as the bracket has 2/3 welds.
This bracket has the threaded insert which locates the belt reel.
Easy option is lap straps a la 911 SC's etc.
andy
