Mike.Gamble
Now things have warmed up a little and the sun is shinning, I'm going to get my roof sorted. I've got a a pair of push rods after the cap broke on one of mine, I've also got a pair of the rams that lift the cover panel as one of mine seemed to have been ever so slightly 'bent' at the top.
I've also got my self a copy of the '101 projects for your Porsche Boxster' which seems very useful and informative.
I also thought I'd check on here as I'm sure I'm following a well worn route!
I take it both plastic ball cap ends should be screwed down the same amount of threads? I only have one of my 'originals' as I threw one away as it was broken before realising it's importance.
Once they are both at the correct length and fitted, as nothing else (motor/winder etc) has been moved or changed will it be a case of everything will be spot on or will it be likely that they will need adjusting as there was obviously something wrong for it to break in the first place?
Any advice or previous experiences greatly received!
