flasher unit
sparks
Hi all,does anyone know where the indicator flasher unit is,on a 1992 968? The car is LHD but that may not make a difference.The fusebox cover is in italian.The indicators come on,but dont flash,hazards are the same,on but not flashing,many thanks......
Hi Sparks - I had an indicator problem this year - indicators stayed on, but hazards worked ok.
Bought a new relay from Halfrauds - problem sorted. Sounds as tho' your issue different tho' - goosed hazards as well.....
Sure - Its in the fuse box under bonnet, mine was far righthand side (as you look from front of bonnet). Pop the top off the fusebox - fur the big square / rectangular relays (ignore fuses) topmost right hand corner, huge relay (silver in my car), underneath that (righthand edge of box), DME relay, underneath that (so coming towards you, still far righthandside) Flasher relay.
IIRC it was around a tenner.
Good luck!
