Flat battery getting into the bonnet ?????
911dino
Gents, the battery has gawn flat on my 996 C2 and I can open the door with the key but the bonnet pull lever will not work! Any ideas on how to open the bonnet to get to the battery??? Many thanks Dean
If Dean's is an early model, prior to the electric release, then he will need to pull the emergency unlocking cable. This is located in the headlamp area, but you need to remove the wheel arch liner to access it.
It is a 1999 Carrera C2 Cab and I have read and re read the hand book and can find nothing with the exception of details of a + terminal in the boot... but hey that won't open either! Electronic I think? May have to go down the cable by the headlight if you would be so kind as to advise more Richard? My email is deanward@btinternet.com if it would be better than open public consumption. I was also thinking of a charger connected to the cig lighter just to get a little power in the battery? Appreciate all of your help, Cheers!
