in your fuse box in the car by your right leg there is a big red pin you pull out to put power into your system, you need to get a live on this and an earth on the checkstrap bracket on the a pillar the metal part. this should give you some power to open the bonnet, if not you have an emergency pull cord which is hidden . should tell you where in your manual as i don't want to post it.
Flat battery
- Thread starter johnk
With a BMW my father owned you had to open the boot with the key and then connect up a battery pack to the boots courtesy light, then you could unlock the doors...
Moving to Boxster Section....
