Flo-Flex bushes
- Thread starter ocallen
It was going to be a track car but finances have improved through work and I'm looking at a 944turbo, 968 or 911 of some variety.
Neil Haughey
Hilux
Definitely, if there is one thing I have learned with these cars over the years it is to stick with new standard bushes and don't waste your money, although some standard bushes are very expensive such as top mounts. All the race cars in PCGB championship for example run standard bushes and you don't hear ppl complaining about the cars being pigs to drive because of bushes flexing.
I feel that new 968 bushes/mounts will be better for road use (EMC use these on tracjk cars too). Delrin and similar bushes alwaus squeek too; and theres little you can do to keep them quiet.
Seconded entirely.
New (standard) bushes will firm up the ride no end and still allow the necessary compliance so the body isnt over stressed. To reduce bush compliance transfers more stress into the body and if too extreme will cause it to crack or welds to seperate unless the body itself is strengthened by top and bottom struts or (ideally) a welded in roll cage. I`m not saying poly bushes shouldnt be fitted but the difference will not be that noticeable in my opinion but the cost will if you do all of them at the same time -which you should as its not good practice to change only some.
As an example (once fitted) my KWV3 and W/M ARB combination made a chip in the windcreen that had been there for a year go into a 5" crack over a weekends motoring and the car has movement (noise) in the rear that wasnt apparent before.
Peter Empson
Peter Empson
ORIGINAL: 944 man
Id have to admit that squeeking on my car would be masked by the ringing in my ears..... []
Pardon?
