when my brakes get hot ...the clutch pedal has a habit of staying depressed and have to hook my foot under it to pull it back up in order to make the next gear change. If I forget to do this then with the pedal already down the clutch doesn't disengage making gear changes a bit of an effort.
Pedal staying depressed doesn't happen if just pootling about ,except that theclutch has to be pushed right to the floor normally otherwise the gearchange is v. difficult, 48km on original clutch.
Does any one else get this floppy clutch when brakes hot?
