Hello Chaps,
Went to reverse Ferdie into the garage one night last week and the gear lever suddenly went all floppy. Seemed to go in gear though, but on lifting the clutch he went forward rather than backwards. oops. After a quick play, I can't get reverse at all and the rest of the gears feel strange as there is no resistance at the gear lever at all. Not having time to do anything else as I was going away for the weekend I pushed him into the garage and left him there.
Having now been through search, I presume this is likely to be a loose nut on the linkage at the gearbox end. However, I also presume that is bit of a bastard to get to, so before I bother getting him moved a bit and jacked up in the cold, is there any chance it could be a problem at the gear lever end - where it's nice and warm and dry inside the car [
Thanks in advance
Thanks in advance
