Patrick,
I'm no expert on flowing heads, but your question reminds me of the quite detailed info on Lindsay Racing website on this subject. There must be significant additional flow with 16v. Porsche went to 16v with 3.0 capacity, they must have figured a 750cc cylinder needed it. Flow is only one advantage of 16v, Audi went to 5v heads for a while. Honda & Mercedes went to 3 valve heads for a while. With an odd number of valves, the inlet is always the greater number.
By my reckoning 3000cc = 1181cubic inches = 0.684cubic ft.
At 6000 rpm thats 0.684x6000= 4104cfm
On a 2.5 litre at 6000rpm its 0.570 x 6000=3417cfm.
If you work out the port opening, -say a 40mm valve with a port below it of say a 36mm open dia, the opening is 3.14x18x18=1017mmsq, less an 8mm dia valve stem, is 3.14x4x4=50, then the Port has an opening of 967mm sq.
If you have two slightly smaller valves as there is less space for them, then assuming a valve of 80% of the 8v equivalent, say 29mm open dia, the numbers are, (3.14x14.5x14.5)x2 valves=1320 less the two stems = 1220mm sq. Thats a 20% increase in port area over the 8v setup. The 2.5 to 3.0 litre capacity represented a 20% increase.
I do not know the actual valve sizes.
I also believe a 3.0 will work fine with a 8v head, (eg 968 Turbo) Cam profile is another variable.
The cfm figures used by the head specialists are measured at a level of pressure to simulate back pressure in the system, and enable them to get a reading. These numbers are just mathmatical facts which I consider are relevant and may be of interest to you. Hopefully they are accurate, if not some-one will surely correct me.
Personally, I prefer 8v engines, for reasons of durability & simplicity. A 968 has long fragile Valve stems not to mention the valve drive mechanism.
George
944t
964rs
