Chaps,
I'd be interested in some points of view on this one ... my S2 has slightly noisy tappets when started from cold. (As an aside, I am of the impression that if you take it for a really hard drive, then park it while still hot, the tappets sound worse the following morning than if it was a fairly normal daily drive. But that's an aside.)
The car is due for an oil and filter service, and I some people have suggested that using a flushing oil may help ... does anyone have any views on this?
It also seems that there are two types of oil flush. First type is a 300 (or so) ml can which you add to the old oil befopre draining it. Add the flush, run the car at idle for 15 minutes and then drain, change filter and refill.
The second type is a very thin oil which you add after having removed the old oil. So, drain old oil, replace sump plug, add thin flushing oil, run at fast idle for 15 minutes, drain, change filters and fill with fresh new (normal) oil.
Has anyone used either of the above products, and if so, do they help with tappy-tappets? Are they any good, are they snake oil, do they damage the engine?
All (informed) opinions welcomed! Thanks.
