Hi Guys, its been a while since I last posed a question.
My Turbo is due a new clutch [
] but after 155K on what appears to be the original according to the history, it is to be expected.
I have opted for the Spec Stage 1 clutch to be used, but I was also considering changing the flywheel for a lighter item whilst the whole area was in bits. Andrew S, has recommended a Lindsey Racing lightened steel wheel.
I'd like to know more about the effects of changing the flywheel on this particular car. By changing the flywheel, I am aware that engine revs increase more quickly and more of the engine power is transfered to the wheels. I am guessing that this would help decrease the turbo lag [8|], or would the car be more likey to bog down when pulling away?
What else would I expect? I would guess increased wheelspin may be introduced if slipping the clutch to make things smoother? I haven't see any posts with anyone going with a lightened flywheel.
I am also planning to have the DPW, new performance chipset and cometic head gasket installed., this should solve my problems with the car only producing 220Bhp shown on the Jamsport Dyno. I have been running with a boost enhancer since then to cater for the weak wastegate.
I am looking foward to having at least 50-60Bhp returned!
Cheers!
Cheers!
