Fog Light - Grommit...
day1zero
Nope not of the Wallace and Grommit fame.....
The rubber grommit/cover that fits over the rear of the fog light (to prevent water ingress) was missing from one side resulting in some minor corrosion....can you buy these as a Porsche part? or is there a universal option etc ?
TVM
Not quite sure what you mean, maybe take a pic
Front fog light? Rear fog light?
but, no, its not available on its own
Front fog light the rubber seal/grommet the one where the bulb cable passes through then seals the back of the light against moisture ingress.
Not shown in the Parts Catalogue !!!
From looking at your other post about LED sidelights, it looks like you have the TechArt brake duct kit which uses a modified VW foglamp.
Maybe your local friendly VW parts dept can identify and supply.
I have also fitted this kit and the photo shows the part number of the lamp unit which may help.
There is nothing like what you are talking about on the standard 993 fog so you must have something non factory
