Fog light housing
First off hi I have just joined the club, there is a way of removing the plastic at the front, pull in order 1st below round plastic then top of round plastic then slight to the left then all the way over to the left then all the way over to the right. Now this panel is off remove the three screws avoiding the one with the spring on it, this is the self adjuster. The pull out the fog lamp and do what you want to do, the bulbs are a twist first then pull out Kind regards Darran
Hi Darren, I've moved this to the regular Cayman area, so you should get some help. One thing, you're showing up as a guest without a user name? You might need to log out and in again, and on the log in screen there's a small box you can tick to remember your user name. I don't know if others can see posts if you're not logged, I can as admin but perhaps someone else could confirm? Thanks [:)]
Also, you could speak to the Cayman Register Secretary. Details are in Porschefile or Porsche Post, on the website, and from Club office. I won't post them here as it's an open forum.
ORIGINAL: pauljmcnulty I don't know if others can see posts if you're not logged, I can as admin but perhaps someone else could confirm?
Yes Paul I can see two posts above yours, both by "Guest" - two different people going on the content of each post? David
Thanks, David. I assumed it was the same person, but if they don't log in there's no access to see. Hopefully he gets it sorted, if there's any problem a call or email to Club office always gets it sorted.
