MartinRS2K
These were available quite a while ago but the original seller is no longer doing them so myself, Jimmy France (Frenchy) and Mike Moore bought up the remaining stock of the strong ABS Plastic lenses and have also sourced the correct fixing screws and outer caps.
The only thing that needs doing to fit the covers is to make 2 small aluminium angled brackets which we have found can vary from car to car depending on the position the lights are fitted and how they sit in the bumper.
We are supplying the following :-
2 x ABS Plastic Foglight Covers (1 x Left, 1 x Right)
2 x M3 A2 Stainless Steel Hex Full Nuts
2 x M3 x 10mm Stainless Steel Screws
2 x Plastic Knurled Cap/Fastener with protective plastic washer
As you can see from the picture of one fitted to my car they look neat when fitted and fully protect the foglights from stones and other debris.
Delivered Price for a pair by Royal Mail Recorded Delivery is £47.00.
There are only 12 pairs available and there are some metal strips already made which will be included with each order until we run out (you may need to modify for your vehicle).
Any questions please ask
Fitted to my 944 Turbo
Angled aluminium steel to fix cover
ABS Plastic Lenses and Fixing Screws
