davidharrow
The blowers either side of the foot-wells are not working. Can someone help me with the diagnosis please ?
Both removed - I replaced - burned out motor, other freed off and lubed. Both tested on a battery off the car and run fine. Fuse OK.
They don't run when I switch the heat / vent fan control in the centre to the right - fresh air centre fan comes on but not the foot-well fans. Engine hot or cold (not sure if this makes any difference, but I have tested it both ways).
Or is there another switch somewhere ?
Help / ideas on diagnosing the source of the problem would be appreciated.
Cheers. David
Cheers. David
