Hello, unless I'm going mad I have some strange behaviour of the foot well blowers. With the ignition off and key removed the blowers were running at slow speed continuously, I had to remove the local 10a fuse for each blower to stop them. Then today I inserted the fuse on the drivers side and the fan didn't run until the ignition was switched on - sorted I thought but when the ignition was switched off the fan continued running. Any ideas gratefully received, thank you. Tim. PS anyone know what the foot well blower series resistor does?
Footwell blowers
- Thread starter nixon
Charles, I thought you had 'retired'!. I have replaced relay no. 1 with a spare. It seemingly has made no difference in that the blower continues at slow speed with ignition off. I have been trying to make sense of the wiring diagram on page 970-52 of Bentley but my auto-electric knowledge is somewhat limited. The blowers will switch to high speed with the controller between the seats with the ignition on and off but the servo operating the heater flap valves only operates with ignition on? I recently installed extra relays for the headlights but i cannot see how that would have caused this issue?Any more thoughts gratefully received. Thanks Tim
Charles, do you know if the heater blower relays are repairable? Just disturbing the relay without actually removing it has temporarily solved the problem but there is obviously something sticky inside and it also makes a horrible noise! That said it is date stamped 1988 so it is probably due for replacement. But thought it was worth asking the question before buying a new one. Thanks Tim
