For those with A/C equipped cars
- Thread starter leepox
bmnelsc
www.porsche.com/.../porscheservice/originalparts/originalpartscatalogue/"Ž
OOPS! file not found
Hmmm - seems like most sources of the PDF catalog are not available - suggest you use Pelican Parts or similar to look it up - Pelican for one does display the Porsche parts diagrams and numbers so you should be able to find it pretty easily.
I would sell you my original unit, as the Aircon switch was ok, but it's the soldered together type and I don't want you to go into this without first checking that you are confident in stripping the unit first. Let me know what you think after looking into the type you have and the type you need.
Hi Paul, the one I have seems to be a thermostat switch connected to a fan speed switch of some sort? The whole assembly looks like this:
Ex Skyline
Do a google search for these words and you'll find a pdf, entitled Heater Control switch LED upgrade. Download it and you'll see the types of controller that were made.
"Using a fine blade or similar implement (and extreme caution so you don't injure yourself!"
My spare controller is the "early" type. If you can make use of my controller let me know.
Incidentally, the OPC charge £110+VAT for the LHS twin button switch!.
Paul
ORIGINAL: Ex Skyline
If I keep the '44 Turbo, the first thing I'm going to do is rip my air con' out! It must weigh at least 50lb [8|].
That's exactly what I did on my turbo, I did have a non AC alternator bracket lying around which helped. Gets rid of some clutter in the engine bay too. I replaced the air con controller with a standard one which seems to plug straight in. Can't say I've missed it. Non of which helps the OP as he has the early dash model.
leepox - It looks like you may have the switch that I mentioned with the booster 477 959 431 attached to it, although I'm only going off the catologue.
Hi Jim, yeah I am contemplating of removing the A/C but then I am thinking of all the rewiring I need to do. It may or may not be simple. There are these three wires that I can't figure out from the wiring diagrams but if i connect the br/yellow to brown the blower fan works, if i connect the br/red to the brown wire the A/C works albeit in full blow mode. So yeah I am now wondering what could have been the configuration inside that bit of the switch that broke off. Really sucks as I can't sit in traffic without overheating, or use the heater when I am getting crazily cold in the car.
Thanks for the help so far guys. Looks like a trip to the dealership for me, but not optimistic how they seem to be as lost as me over the phone.
